rwmorrisonjr
UPDATE: Truck is aligned, but the Firestone tech said he couldn't adjust the camber since I didn't install a camber adjustment kit when I swapped out the LCAs! What a bunch of garbage since they've been able to set the alignment with the factory hardware since I bought he truck!
The front brakes are still dragging evenly but not pulling to either side. Still trying to troubleshoot this since I find it very hard to believe that both calipers and flex lines have failed in the exact same way. Now I'm leaning toward the master cylinder based on the even dragging of the calipers.
