Excessive dirt & rocks in underbody and frame
Going_Going_Gone
Phoenix
Just go to a self service car wash and spray the underbody or if you have a power washer spray the vehicle. Be careful that you don't damage plastic trim or graphics (if applicable).
There's aways the shade tree undercarriage wash method: place an oscillating lawn sprinkler under the vehicle.
Fastcar
FL
I was planning on spraying it this weekend and seeing how much better I can clean it up.
While I AM constantly finding new places where dirt is located, I do not think it is that dirt is returning after washing it out. More so that dirt is continuing to appear out of places I have not been able to fully clean out, i.e. behind the 3rd brake light onto the rear window and at body panel seams and trim pieces. I pulled the front bumper assembly off and removed the front license plate bracket within the first couple months of owning it. I remember it being quite dusty and rocks/pebbles throughout.
One concern I had with the amount that is actually inside of the frame is that it had been buried/sunk in mud or something. I would have thought a flooded or sunk vehicle would exhibit major issues and failures mechanically/electrically and hopefully show up on vehicle history (none of which are present at the time). The running boards are fine and nothing else looks out of place.
My intention is to have a good detail and advise the shop to get in the nooks and crannies on the exterior to try and get this taken care of.
That was my fear. I live in East TN so not much corrosion otherwise to worry about, but I suspected this left unchecked for extended time would not be ideal in the long run.
If you are concerned about water, look at the bolts that holds the seats to the floor. Raise the carpet in places and check for moisture.
sjwhiteley
Kentucky
Sounds like you might have to crawl under there with a brush and hose. I’ve had to take some panels off to clean out straw, stones and various areas with dirt accumulation. That back bumper cover area does seem to accumulate more than it’s fair share.
Hellwig
Electric rv pressure washers usually work with low PSI (500ish). That may help this situation.
GlennSullivan
Yorktown NY & Jupiter FL
That vehicle has def been on some muddy, dirty roads, hopefully not up to the axles. As others have said, it should be thoroughly cleaned with a low to medium pressure washer and brush.
