Update all versions of Ford Sync 3 to the latest Sync 3.4
Overtow
CLEVELAND
2. Waze via what? Applink? CarPlay? Android Auto? Aftermarket Wifi Adapter?
Waze via Android Auto. Its worked fine for me for years, but I just recently upgraded to a new Pixel 6a and I started having the problems shortly thereafter, maybe immediately on the switch. I was hoping that the 3.4.22110 upgrade would solve the issue but sadly that is not the case. This is likely a Google issue:
Jharpe
O’Fallon, MO
Has anyone had issues with the ambient lighting after updating? I just updated from 3.0.17276 to 3.4.22110 and now my ambient lights are not working. The function is still there in the menu. I did the master reset as suggested by Cyanlabs at the end of the update. I have an ‘18 max platinum.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Master reset is hardly ever needed. Most of the time a simple reboot of Sync, using the method I described above.
For an 18, hold the Radio Power button and Next Track, until screen goes black. Do that 2 times in a row, then try the menu again.
Overtow
CLEVELAND
Ambient lighting works fine for me on 22110.
Jharpe
O’Fallon, MO
That reset worked. Thanks LokiWolf! Saved me from the doghouse with the Mrs!! Lol
MxRacer965
Hudsonville, MI
Anyone keeping eyes peeled for a Sync 4 update? I would imagine should this even be possible it would require some new hardware. I think infotainment.com has a F150 kit to go from Sync 3 to 4 but I haven’t reached out about Expy. I’d pony up for new version if I had to buy some new hardware. I plan to keep the Expy for 6-7 more years or so. It’d be worth it to me.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Haven’t looked at the 150 kit, but would probably work. Yes, will need new hardware.
