2003 Rear HVAC control knobs replacement direction’s
Eightiesrock80
Frankfort, IL
How do I remove the two knobs I can’t seem to figure out how to take the panel or trim off that surround them two knobs. So I can take the screws out to replace the bulbs in the back (Second Row) The little green light that is supposed to go on when the air is coming out of the ceiling is not lighting up so I want to replace the bulbs
whtbronco
Winchester, VA
Hmm, I can't find anything in AllData for removing the knobs on the Rear Integrated Control Panel. I've never tried and off hand have no idea.
whtbronco
Winchester, VA
Okay, so now that I have seen the panel that looks like mine, screen shot below, I have an idea. I'm gonna say that it either is secured from the back of the trim, from inside the console or it just snaps on like most of the trim. I think pulling the inside of the center console out will show you if there's nuts or screws that hold the trim on from the back. If not it must be just that it snaps on.
All that said, I'm not sure you're gonna be able to replace the lamps, see the back screen shot below.
whtbronco
Winchester, VA
Aspen03
Indianapolis
It doesn't just pop off, the center console liner has to be disassembled to get at that. I've never looked into those but I would be willing to bet those are a surface mount led for the lights as opposed to a normal bulb.
Eightiesrock80
Eightiesrock80
Frankfort, IL
Oh thank you both Aspen, and white Bronco this really helped me and a extremely lot. I’m going to start from the inside of the middle council
Eightiesrock80
Eightiesrock80
Frankfort, IL
I see the blue lightbulb holder in the middle but I don’t think that lightbulb is for the little green light that switches from floor to vent that’s the light I wanted to replace because one of the green lights doesn’t come on. The knobs light up though. I guess I shouldn’t really be concerned about the little green lights at least everything works except for those two little lights
Aspen03
Indianapolis
If that's the only problem I'd personally leave it alone. It's a fair amount of disassembly for something more or less trivial. In the entire time we've owned both our trucks we've never had them on floor for the rear. The overall temp is much more controllable with the roof vents and each passenger can somewhat tailor the climate of their specific seat by adjusting the vents above.
The 2nd row roof vents are also nice if you have no passengers you can rotate them 180 degrees so the louvers face the driver seat and get extra heat or cooling if you want. I do this in the hottest days of summer. With remote start you always have an ice cold seat to hop into because it's getting blasted from in front and up above.
whtbronco
Winchester, VA
I agree 100% with Aspen, the lights just ain't worth it. We use the rear HVAC exactly the same way.
The amount of work to disassemble that center console makes me wonder if I wanna disassemble the console for sound deadening or just remove the seats and work around the console.
