bman440440
My 08 EB VIN 1FMFU18548LA55397 is having issues... when its cold out its worse but it still does it when warm... it will go down at what I think is a normal speed but coming up its REALLY slow... worse when cold.
I have tried shooting some silicone spray lube in the tracks and it helps a little.
I'm trying to figure out if it is a motor that is weak or a regulator issue. So before I pull it apart I want to have a new regulator and motor on hand but the options I have for the motor are 2 pin or 8 pin connector... how do I figure this out without taking it apart?
Also does anyone have any recommendations on how to figure out if its a motor or regulator issue?
