Labor costs for idle tensioner belt pulleys on a 2003 expedition.
Jstekk
Hillsboro Oregon
I'm wondering about my belt pulleys and my tensioner pulley in my 2003 expedition. How long does it take a mechanic to replace all four pulleys.
I found a video where he replaced two of them but it doesn't say how long it took him but it was very extremely easy!
Please help, I'm a disabled veteran and I need this fix cheap enough to survive this.
*Ford Expedition Drive Belt Idler Pulley Replacement Cost*. REPAIR PAL
The average cost for a Ford Expedition Drive Belt Idler Pulley Replacement is between $104 and $121.
Labor costs are estimated between $51 and $65 while parts are priced between $53 and $57.
https://repairpal.com/estimator/ford/expedition/drive-belt-idler-pulley-replacement-cost
Duralast Belt Tensioner 305263 ★ belt tensioner
2003 Ford Expedition
Part #305263
SKU #428859
1-Year Warranty
$48.99
Duralast Idler Pulley 231051 *ribbed pulley
Shop All Duralast
Part #231051
SKU #634110
1-Year Warranty
$22.49
Duralast Belt 852K7 *serpentine belt
Shop All Duralast
Part #852K7
SKU #165304
1-Year Warranty
$22.99
Duralast Idler Pulley 231098 *smooth pulley
Shop All Duralast
Part # 231098
SKU # 909940
1-Year Warranty
$16.99______________
Duralast Idler Pulley 231052. *smooth pulley
Shop all Duralast
Part #231052. Same part as directly above...↑
SKU #634111
1-Year Warranty
$18.99______________.
Please everyone, help me to try to find the labor hours involved in four idle tensioner pulleys and serpentine belt replacement!
**Ford expedition idler pulley replacement ….5:14. Video link to youtube
____________________________________________
whtbronco
Winchester, VA
Belt: .3hrs
Tensioner: .5hrs
Idlers: Can't find that. I would guess .25hrs for each of the 3.
So probably 1.5 - 2 hours total. It took me about an hour to swap all of it.
whtbronco
Winchester, VA
For what it's worth here's what I bought from Rock Auto:
Belt: Motorcraft $26
Tensioner: Motorcraft $40
Idler smooth: Motorcraft $25ea
Idler ribbed: Litens purchased from Advanced Auto locally.
I've grown tired of replacing parts twice and the Motorcraft branded parts while not as good as factory parts still last much longer than the other aftermarket parts in many cases. For instance I replaced both smooth idler pulleys with Hayden brand and 1 failed with the other not feeling good in less than 2yrs.
GlennSullivan
Yorktown NY & Jupiter FL
Actual time to perform the job really has nothing to do with what you get charged. Nearly every auto repair shop go by what is referred to as the flat rate time, which is a pre determined cost to do any given job. If someone on here has access to flat rate costs, maybe they can post the price.
Mr_Kostas
Waukesha WI
Idler pulley :
Model Year​
Skill Code​
Factory Time​
MOTOR Time​
IDLER PULLEY, R&R​
Expedition, Navigator,​
One ...................................​
2003-04​
B
0.4​
0.5​
Two Or More ...........................​
2003-04​
B
0.4​
0.5​
Model Year​
Skill Code​
Factory Time​
MOTOR Time​
P/S PULLEY, R&R​
Expedition, Navigator ..................​
2003-06​
B
0.9​
Model Year​
Skill Code​
Factory Time​
MOTOR Time​
SERPENTINE BELT, R&R​
Expedition,​
4.6L ..................................​
2003-04​
C
0.4​
0.5​
5.4L ..................................​
2003-06​
C
0.2​
0.3​
Navigator ..............................​
1998-06​
C
0.4​
0.5​
Model Year​
Skill Code​
Factory Time​
MOTOR Time​
BELT TENSIONER, R&R​
2003-04​
B
0.5​
0.6​
2003-04​
B
0.4​
0.5​
ediddily
Nevada
Personally, if you have a set of tools I would suggest you do it yourself as its not that hard and lead you to RockAuto.com for auto parts. You pay for shipping, but the overall savings compared to the Big stores (Oreily/Autozone/Napa) is nearly 50% or more. I only go to the Big stores if I seriously need a part in the moment. This job would take you 1-2 hrs depending on your handy skills. The only annoying part would be the fan being in the way, but you can get it done. You can save yourself a couple hundred dollars on labor and use that money for beer and fixing the car or take your partner out for dinner. I always tell my wife that "yes, it takes time, but saves money on labor and you can use that money on your stupid bags/purses." Also, you can youtube anything if you don't know how to do the job.
Tools you'll need for this job would include:
Harbor freight: belt tensioner tool, Harbor freight - belt tensioner
Any mechanic's tool set
Rockauto belt/pulleys
Belt: $9-$31
Tensioner" $20-$40
Idler Pulley: $5-$35
Tensioner Pulley: $6-$18
riphip
Memphis, TN.
Wish you were in my area. You would get the parts, preferably Rockauto & Motorcraft, I would replace with free labor.
Thank You fir Your Service!!!!
aa240sx
San Diego
This one is definitely a DIY job. I literally just did this a month ago and it took only an hour. Toughest part of the job is belt routing.
