2018 Expedition Engine Knocking?
SyndicateZ
Mass
I can't even spell mechanic, but that isn't right. Sounds like a diesel. Tell them if that's "normal", go out and find ANY 3.5 on their lot and listen to it to compare.
Chances are that other Expy will have some type of noiseand still try to say "see, they all make a noise"
bwhite8889
bwhite8889
DFW
Issue couldn't be directly replicated at the dealership (go figure!) since it's somewhat intermittent. However, I was able to provide several videos and without taking it apart yet they believe it may be timing chain related. Either the chain itself or the tensioner. More to come as I get more information.
R0cketMan
Ann Arbor, MI
If your expy is making that noise just after having the VCT work done, they likely screwed up the timing when putting it back together. That sound reminds me of an old motorcycle I had when I was young. I rebuilt the engine and it had a similar "tapping" sound but only 1 tap since it was a v-twin sohc. I found out that the timing chain was off by 1 tooth, advancing the cam timing and opening the intake valve much earlier than is safe so as the piston came up to TDC, it "tapped" the intake valve. That is piston-valve contact and is not good. Do not drive it, have it towed. Have them give you a new engine while your at it because they screwed up yours.
bwhite8889
bwhite8889
DFW
Nothing so far. Although according to Rocketman I need to be asking for a new engine…
I’m going to call the dealer rep tomorrow if so don’t hear anything by then.
SyndicateZ
Mass
Meh, they will prolly just need to re- time the chain and or install new guides etc.
bwhite8889
bwhite8889
DFW
That’s what I was thinking. I texted my rep and asked for pictures of the chain, tensioners, guides, pistons, and valves to verify that the diligence was done and no internal damage was found.
bwhite8889
bwhite8889
DFW
Heard back from the dealer today. They took it apart and verified no damage to the timing chain or any of its components. What they did find was that one of the new VCT cam phasers was bad so they are replacing it again.
One possibility is that they used the old-style part number (starts with an ‘H’ instead of an ‘M’) because they have a surplus of them ever since the newer ‘M’ styles were released to fix this known issue in the eco-boost engines. Either that or the job was just botched.
Should have it back Wednesday or so and can post a video of how the engine sounds.
Bmac1955
Southern Cali
I had my phasers replaced on my 2019 in 11/ 21 with 35k on it. They replaced it with the old style phasers. I have 40k on it now. Don't drive it alot although I have had oil changes at 5k mile intervals. I flood start upon first startup in the AM. I do have Ford Protect warranty. So I was pissed that the old style was installed. Getting the repair done I had took a video upon startup in the AM to show that there was a issue. They couldn't say it was normal. That was my concern replacing phasers with a known failure rate. That's (Job 1) for you. Glad you were taken properly care of.
bwhite8889
bwhite8889
DFW
Picked it up today. Looking over the report it looks like they did in fact replace a tensioner as well as the left side VCTs again. Sound is gone so far.
Only other oddity, which may be attributable to my heightened sense of awareness after having the engine apart twice, is when the turbo kicks in now there is a sound that almost reminds me of a static white noise machine. I’m not making too much of it (yet) since it’s not unbearably loud but definitely something that wasn’t there before.
