ExpyAlaDocious
2005 Ford Expedition
Can't siphon gas?
Long story short- fuel pump died right after I filled gas up. 20+ gal in the tank, and I need to siphon it out so I can attempt to drop the tank and replace the pump.
The Problem: Where's the gas? I got a 6' hose, stuck it in as far as it will let me go until it stops (nearly 4-5'). It hits bottom or a stopping point- Can't get it to siphon- just pulls fumes. I pull the hose out, and it's BONE DRY. No gas on the hose at all. If I'm not hitting the bottom, there's something in the way stopping the hose from going lower... do I need a longer hose and how do I push it further in when something's stopping it?
Now, I've confirmed it's a full tank on the gauge, and again, I JUST filled up. Is there some sort of anti-siphon thing or a trick a moron like me doesn't know about? How can I siphon this?
Thank you!
Can't siphon gas?
Thank you!
