07 high beam does not work on drivers side
Anubis
The Gorge
When I turn on the bright lights the driver's side does not come on. Assumed the bulbs burned out so I purchase some LED lights and they are much brighter but the one bright light still does not work.
Checked the fuses and they are good to go.
This is a ex-K9 unit so many lights were removed and the interior lights do not come either. Will investigate that later.
Any suggestions on where to start.
Plati
Had something like that on a Vibe once. The brass terminal inside the connector to light had bent and wasn't seated. Easy fix once you discover it! YMMV
Had been in an accident on that corner (hit a deer) …. problem showed up later.
I got a wiring diagram, used an volt/ohm meter and traced it to where it wasn't connecting.
stamp11127
Temple, Georgia
Check for power at the headlight connector. If not present then check splice S109.
  • 2007.1.pdf
Anubis
Anubis
The Gorge
Thanks for the feedback. Ill check that out tomorrow, ordered the wiring book off Ebay today since it looks like I will need it.
Member Recommended
Staff online
bryandreilly
