This week I will be working on my 1999 Expedition XLT, it was in an accident caused by another driver who left the scene after my SUV went plowing through a utility pole. That is the short story on that.
Now onto the work, my radiator support is rusting away just the way Ford likes it, was putting it off for better weather, but, along came the accident, now I want to fix it sooner rather then later, for one , I do not like looking at it in the condition it is in.
As you can see by the images, half the job the tear down is already done, just need to remove the fenders to access the spot welds for the support, and some other parts still connected to the support
Going through a utility pole, the odds of the vehicle being totaled is pretty high, considering it went through it at 45mph.
Other then the bumper, grill, radiator support, clutch fan, radiator, a/c core , both coolers,trans lines, which is easily replaced.
That spot that took the pole out, was the cross member, it now has a big dent, well that got me a bit worried, went over the frame to see how bad it got messed up, the driver side moved back about a 1/4 ", nothing a frame rack can not handle, so I will fix it.
I will be working on it all week, I have no need to rush through this, got other vehicles to drive, so when i get the fenders off and couple of other parts, i will post images of removing radiator support, a lot of spot weld drilling comming up.
And alot of parts to buy
