67fe390
Good morning from Australia thank you for me join this group
I have a 2000 eddie bauer with 5.4 with only 67000 km
I have tried the following to fix the high idle (1150rpm)
Replacement inlet manifold as it was leaking coolant.
Replace the following
ICV with a motorcraft unit
MAF sensor
TPS
Temperature Sensor in the head
Pvc and rubber fittings
Egr valve as it was leaking around the shaft
Cheak brake booster and evac line not leaking
Smoke tested no leaks
So now i'm open for any suggestions, because I can't see any others that may be causement
Run Forscan and the only code that I can't remove P1000
Following code
C1170 abs, code for the adjustable pedals
Any suggestions, that might help. I'm open for please.
MAF sensor
TPS
Following code
