2002 4.6l valve cover grommets
wdntulk2no
TN
Hey guys I didn’t see anything about this so posing looking for some answers. I have leaky valve covers on both sides. When I went to change valve cover gaskets I also ordered the grommets as well. The old grommets have a metal core but the new ones do not. I have not been able to determine if this core is needed or if it was designed out. None of the sets seem to come with the core. Any advice is helpful. I really don’t want to have to do this again.
W
wdntulk2no
TN
Ok so after digging and finally finding a 20+ year ford mechanic I was told to dig the core out of the old rubber and install into the new rubber. Let me tell you that is a job in itself. I used a little dielectric on the core and a screwdriver that fit perfectly in the metal core. Once they were all outfitted with the core the rubber looked way closer to the original units that had split and cracked. My best guess is this is the Windsor engine version based on ford documentation. Side note you can buy these from ford they are 16$ each total of 22 in this valve cover set.
wpatters1229
Pleasant Hill CA
They are $$$. The metal core is so you do not use the rubber grommet to hold down the cover. The metal core lets the nut put pressure on the valve cover. The rubber is to seal around the hole. Putting the old tube into the new grommets is the right thing to do but probably should get OEM to do it right...if you already did the swap, you will probably be fine.
chrismomo5969
