My 4x4 works great.You may also want to check your 4 wheel activators, they are vacuum activated and in some cases, the solenoid or vacuum line can be the issue. The solenoid is attached to the firewall on the passenger side and on earlier versions, the solenoid did not have a cover and water could corrode, ford later puts a cover on to lessen issue. If the solenoid or vacuum is not working correctly that could partially keep the 4 wheel activator engaged where the teeth on the activators will tough a bit.
Which issue am I having that I need to check the solenoid or vacuum lines ??
Sorry if I am misunderstanding your reply.
Thx
Sent from my Nexus 6P using Tapatalk
