justin
Hi all,
I recently got a 2003 expedition Xlt. When I got i t the previous owner thought it had a bad trans. But as it turned out the second cat on the passenger side broke loose and was restricting exhaust flow not letting it shift.
I removed the cat to see if it helped and it did. The truck ran good but not top notch.
It seemed to lack a little power. But however recently it has very little power. It takes forever to get to 35 mph and on hills forget it!
I cut loose the exhaust and moved it to the side to see if the muffler may have plugged up due to the bad cat i removed with no luck.
When I bought it it had no check engine light or anything. Recently the check engine light came on and was flashing. I had the codes read and it said there was a misfire on cyl. 7, something about the a/c (wich works fine), and something about the pats system ( wich works fine obviously because it starts). But I shut it off and the next time i started the truck the check engine light was off. When it was on it was running kind of rough but is no longer doning that since it shut off.
I dont expect a sports car out of it but it cant get out of its own way!!!
Can someone plese help me!!! I love this truck! But dont want to spend a fortune fixing it. I am kinda handy when it comes to cars so if i can id like to fix it myself if at all possible.
If any other info may help please ask!
Thanks,
Justin
Thanks,
Justin
