amish_electrician
A/C compressor on my 2004 5.4L started making whirring sound (increased with RPM). Ruled out the clutch as the cause, so decided to play it safe and replace the compressor.
I don't wish this repair on anyone.
Drained oil from compressor, condenser and accumulator. Looked good... some dye, but no nasty black muck or metal debris. Think I caught compressor before it self destructed. Got the new compressor oiled and installed and then replaced the condenser and accumulator. Evacuated system for 1 hour. Holds vacuum... no leaks. My questions:
1) Since compressor had not failed catastrophically, I opted to just replace the compressor, condenser and accumulator. Didn't flush the lines or mess with the expansion valves or evaporators. Any opinions on this approach... good or bad?
2) While recharging the system with R134a, while shaking one of the cans, I noticed that the line connected to the can tap had become loose. (Harbor Freight manifold gauges... yeah, I know...) It hadn't loosened that much and I didn't hear any gas escaping. I hand tightened the line again and went about my business. What are the odds that air got introduced to the system? And if so, should I worry about it? Recover, evac and recharge again (being more careful)? Or am I over-thinking this one? A/C is nice and frosty cold by the way.
Thanks for any opinions or advice!
