Pantera2077
Good morning.
Title says it.
Did some searching and found a few threads about this.
Car starts and runs.
Column gear select.
Brake lights work - Can the switch still be bad if I have brake lights?
Neutral safety switch??? Pulled lever off and still does not move on the column.
Some threads talk about an override button under the column. I certainly do not see it and the only plug under the column cover goes back to the firewall.
A thread said shift interlock solenoid and there were some videos on YouTube on that, but they were years up to 2003. Searching RockAuto does not show a part for a shift interlock solenoid for a 2004.
Any thoughts?
Title says it.
Column gear select.
Any thoughts?
