Rob Adams
Not really needed if the fan & clutch are working properly[/QUOTE]You can answer your questions with a little thought:
A) is this normal on these expys? Poor AC when idle/not moving?
No - wouldn't sell very many if it was. You should have cool/cold air withing a few seconds of startup.
B) does anybody know of an improved set of fan blades to draw more air? or, alternately is there a combined condenser radiator part that would drop in and replace the 2 individual "thin" radiators and thus eliminate the gap?
Fan - yes but there will be a cost in mpg - bigger blades and increased pitch - HD Fan
Combo - no
c) could this be a fan clutch problem? I don't deal with high engine temps at Idle, so i think the radiator is getting enough airflow
Engine produces more heat energy as the rpms increase so forward movement usually will aid in cooling
d)any recommendations for a bolt on additional electric condenser fan? I'd rather not convert and go full electric (removing the factory fan from the front of the motor) Just looking to get some additional airflow at idle...maybe a switch I can toggle on the dash to add some extra airflow.
Thank you Stamp...truly I appreciate the answers
