2007 Expedition EL Center Console
marlinpruett
South Carolina
Has anyone removed the top of the center console?
If so could you briefly describe the process. I want to install some courtesy lights and need to get inside the console for the wiring hookups.\
I also need to do some house keeping in there for spilled coffee.
Pull up that little rubber crater panel below the radio and there will be a bolt under it that holds the top down. There will also be two other bolts you can access after you loosen that bolt and remove the top area.
