chevy24d
I am thinking of using the blue e-brake wire under the dash. I want to connect this reverse light circuit you mentioned under the hood, to this harness under the dash. Then, at the trailer hitch I will wire the blue wire to the reverse light circuit as I do not have or need electric brakes. I will also connect my new back up camera power lead to this. I am hesitant to tie off my existing reverse light wire because I checked it out today and the wire size was extremely small. I know the camera is low power and the reverse solenoid is less than an amp, but if I can use a separate circuit it will be better. I hope you can tell me how to pick up this fused wire so I can bring it into the plug under the dash.Originally posted by tk1971
One more thing for anyone wanting to do this, but didn't go through the entire thread. The non-HD tow Expies have the same fuse box under the hood. Putting a 30amp fuse and relay in place will get a fused/relay-controlled 12V to the hitch wiring harness connector up to the engine compartment. You will have to run a 10 gauge wire to the back of the vehicle to get the trailer charging 12V back there.
There is also a 15amp fused reverse 12V at the fuse box that ends in the engine compartment harness. There really is no need to pull this one, as you can get a reverse 12V by tapping one of the reverse lights at the back of the vehicle. But since I was pulling the 12V, putting another wire in the flexible wiring loom is really no work at all.tk
Thanks for all your help. Mark
BTW - I am using the 4 to 6/4 combo unit and yes, my friend works at a sheet metal shop and we went there today to make my fancy bracket!
