2008 EL strut replacement recommendations
mothra
Wilmington, NC
My 2008 Ford Expedition EL 2WD Limited suspension has finally gotten to bad to ignore. I think I am going to go with the strutmasters rear conversion to get rid of my leaky air bags. Unfortunately they do not make a front strut for the EL Limited. What is the best option for a front (loaded strut assembly) that will retain oem ride height? And if there is a better option for the rear I am open to something different.
flyguy
Richland, WA
The suspension on our 2015 Expedition Limited went from bad to worse to the point it thru my back out going over a speed bump. I replaced the shocks with Bilsteins from https://www.shocksurplus.com/. The total cost plus installation was $1,600. The ride now is perfect; instead of 4-5 bounces after going over a speed bump, it is only one.
DoubleAction
Seminole Florida
I used Monroe struts which is a fully assemble shock and spring assembly. They have a lifetime warranty and on Amazon the total for all 4 was under $500. I have them on a 3/2 ready lift and so far have been great.
