2008 Expedition- mechanic states valve cover gasket leak
Trainmaster
Old School Member
Rockaway Beach, NY
No. The jobs not worth half that price.
Try tightening the bolts a half turn and cleaning the thing off and it may only cost you ten minutes and a $5 can of Gumout.
Hamfisted
Ft Lauderdale
If you can't do the work yourself, call around to several shops and get valve cover gasket replacement quotes. The gasket set itself is about $30 at Rock Auto.
Although labor cost for shops has risen steeply in the last several years, you can probably find some lower quotes for the job. Is it leaking enough to leave oil on your driveway ? Might just try cleaning the old grime off with some degreaser and a parts brush. The bolts aren't loose right ?
Fel Pro Valve Cover Gasket Set at Rock Auto
