I’ve dug through the Forscan list, it’s so random and huge that it’s hard to look for certain stuff in that thread.
I have a 2008 Limited, and just learned through the forum that apparently the Limiteds lighting is controlled through the BCM, and that i’d be able to disable the hyper flash through Forscan. Some say they did it successfully, others say it only worked for the rear. Either way, i’d like to try, but I haven’t been able to find out what to modify.
I have a knockoff ELM327, and Windows laptop with the extended license.
I also was curious about a few other tweaks.
Is there a Bambi Mode for us? (Through Forscan) Keeping the fogs on with the brights? In older vehicles, it was typically as simple as cutting a pin off the fog light relay. I haven’t seen much info for third gens.
Also interested in disabling the key in ignition chimes when the doors open and such. Any mods for that?
I had a whole list that I am drawing a blank on, so when I think of them, I’ll leave a response with them as well. Or if anyone knows of a decent list that would be cool as well!
Thanks in advance!
Thanks in advance!
