2010 Dash lights out
C Trost
Maryland
Had battery issue now a few sections of dash night lights are out. Headlight switch selections, 4x4 switch selections, shifter selection, and the 6 buttons above the nav/radio display(info, reset, setup, trac cont, hazard, lift gate) I assume these are lite up. How do you get access to these to fix ??
99WhiteC5Coupe
You may want to provide more information on the, “battery issue”, which may help others determine for you what may be the problem.
Is it possible the dimmer switch for the dash lights is turned off or to the low position?
C
C Trost
Maryland
The battery issue blew one instr. panel fuse and radio fuse. Replaced those, everything in the truck works except those sections of lights.
Staff online
bryandreilly
