Almost. The PCM doesn't send 12V to the relay. A couple things:
1) To crank the starter, two main things must occur: the ignition key and all upstream items must allow power to flow to Pin 1, and the PCM must connect Pin 2 to ground. This creates a closed circuit that allows power to flow from the battery, through the ignition switch and a few other elements, through the starter relay low-power/control circuit, and finally to ground.
2) The purpose of a relay is to use a low-power/control signal to close a high-power circuit. For the Starter Relay shown in my previous post, the +12V from the ignition circuit arrives at Pin 1 on the relay when the ignition switch is in start position and all upstream mechanical connections are closed, thus indicating the driver is trying to start the engine. In most cases, Pin 2 is already connected to ground, in which case the presence of +12V on Pin 1 closes the low-power/control circuit and allows current to flow between Pin 1 to Pin 2 on the relay, effectively activating the low power/control circuit within the relay. The presence of current flowing through the low-power circuit within the relay creates an electromagnetic flux that closes the high-power switch in the relay connecting Pins 3 and 5. Pins 3 and 5 represent the high-power side of the circuit and, when closed, allows enough power to flow to close the starter solenoid and crank the starter.
3) The design used by Ford, and I suspect rather common in the automotive industry, is for Pin 2 in the low-power/control side of the relay to remain disconnected from ground (open) unless the PCM closes it. This prevents current from flowing from Pin 1 to Pin 2, and thus does not create a flux that will close the switch between Pins 3 and 5 and so the starter does not activate. Inside of the PCM is effectively another relay that will connect the starter relay Pin 2 to ground when it is closed, which only happens when the PCM decides the engine should be allowed to start. At all other times, the PCM keeps that internal relay open, which keeps the low-power/control side of the starter relay open, which prevents the starter motor from cranking.
4) Using the below image, if you start at the SMART JUNCTION BOX, we can follow the circuit during a start request:
- F27 (Fuse #27 I think) is connected directly to the battery, so it always has +12V on it.
- Moving downward, out of the SMART JUNCTION BOX at connector C2280A and leading to connector C250 (Pin 9) at the ignition switch. This circuit is always hot (+12V). When the driver turns the key to Start, the switch moves over to Position 4, which connects the +12V from the SMART JUNCTION BOX to the output Pin 10.
- The +12V leaves the IGNITION SWITCH through connector C250 (Pin 10), through the remote starter system (if equipped), and eventually splitting and going to connector C175B (Pin 16) and the BATTERY JUNCTION BOX - START DIODE.
-- The presence of +12V at the connection to the PCM at C175B Pin 16 tells the PCM that the driver is requesting an engine start. Internal logic in the PCM activates some other checks and preparations for engine start.
-- A diode, such as the START DIODE, is used to ensure current only flows in one direction, in this case from the top of the picture to lower in the picture. Although the book doesn't say, I suspect that diode exists because providing power to the POWER DISTRIBUTION/SJB may introduce some risk of reverse power flow. Unless the diode is faulty, we can safely ignore it for this discussion.
-- On the low side of the BATTERY JUNCTION BOX (BJB) is a connection to the STARTING SYSTEM (20-1) at marker A. This is the connection to the picture in my previous post at the top. 20-1 is the page number in the manual I am using.
- At the top of page 20-1, at marker A, +12V should be present at CDC38, the White wire with a Violet stripe since the driver has requested an engine start (from the below picture).
- In this condition, CDC38 provides +12V power to the starter relay low-power/control circuit (Pin 1).
- The PCM, seeing the presence of +12V at Pin 16 (below pic) and therefore understanding that the driver is trying to start the engine, will make a decision. If all start conditions are met (as before: security, safety, transmission position, etc.), it will use an internal PCM relay to connect Connector C175B Pin 7 to ground, creating a closed circuit from the battery and through all of the above elements, and thus allow power to flow through the starter relay low-power/control circuit. If conditions are not met, or, in my case, the internal PCM relay is burned out, it will leave Pin 7 open (NOT connected to ground) and the starter relay low-power/control circuit will remain open, power will NOT flow through the starter relay low-power/control circuit, and the starter relay high-power switch (Pins 3 and 5) will remain open.
- If power starts flowing through the starter relay low-power/control circuit, it will create a flux that closes the high-power switch in the relay, connecting Pins 3 and 5, and allow high power to flow to the starter from Pin 5, through CDC25, and eventually to Connector C197B Pin 1 at the starter motor. Internally, that is the low-power/control side of the starter solenoid, which is just a big relay that allows/disallows starter power to flow from the battery (C1100C/A) to the starter itself.
To answer your questions:
- Testing for presence of +12V at starter relay Pin 1 is a good idea. I don't recall for sure, but it may only be hot when the ignition is in the start position. Be sure to measure against a good ground (don't try to use Pin 2 as the ground -- it is probably open/not grounded).
- If the PCM is working properly, and the wiring and connections are good, then testing starter relay to ground while the ignition is in the start position is also a good idea. If the PCM is faulty, or if a wire/connection between the BATTERY JUNCTION BOX and the PCM is bad, then it will be open. I *think* you can remove the starter relay and check for connectivity to ground while the ignition switch is in start because the PCM should see the signal from C175B Pin 16 below and therefore close its internal relay and connect starter relay Pin 2 to ground.
- Yes, I shorted the Yellow wire running into the PCM (Connector C175B Pin 7) to ground (being sure to leave myself enough wire at the PCM in case I wanted to undo it). That effetively bypasses what I believe is a burned out relay inside the PCM. I recommend you test this before cutting anything -- have someone turn the ignition key to start, and run a jumper from Pin 7 to the neighboring grounding block. Note that the wire at Pin 7 is very small and you will want to avoid jamming anything large in the back of the connector at the PCM as doing so could damage it. I think I used either a paperclip connected to a jumper from my multimeter, or something equivalent. If the starter turns over, then you have verified that everything up to the PCM is working as intended. This still doesn't entirely rule out of some other sensor the PCM is seeing as not allowing a start condition, but by staring at Forscan for a while you can probably gain some comfort if that is or is not the case.
