timbersteel
Hello everyone,
I wanted to say this forum has been exceptional when I have researched my 2010 Expedition EL and my wife's 2010 Expedition Eddie Bauer.
I have run into an issue, where I'm coming to a stop, whether traffic or signals to stop, I always have this "lurch" or also a "Harsh Bump Shift".
My 2010 EL has 254,*** miles and I owned it for the last 6,000, 2 years. It's always had this and it's is annoying. I've already performed a transmission fluid and change, several times, with Mercon LV. Throttle body was replaced with New Motorcraft Throttle body. It also came with a new TPS as well. That was replaced due to rough idle, High, hanging idle, and shaking. That solved all those issues.
I did the front brakes, all with Motorcraft calipers and hoses. Rear brakes are fine. It's not showing any stores codes or pending. I've done the throttle body reset as well. I have also checked and there is a TSB regarding this issue, but seems it only applies to 2008 Expeditions with the 6r80 transmission.
My wife's 2010 Expedition, with 202,000 miles, doesn't exhibit this behavior and it's been badly neglected from a previous owner or owners..not sure. But I'd doesn't exhibit any harsh or bump shift when coming to a stop.
One thing I noticed between hers and mine is the drive by wire from the accelerator pedal module. I can hold her engine RPM's and any range from idle to 3k, but with mine, it's is either idle or just goes up to 2k, 2.5k, or 3k. It's hard to find any sweet spot to hold the throttle.
I'm not used to the newer electrical aspects of the Ford's, but I have owned a 2002 Dodge 5.9, 2004 5.7 Dodge Hemi, 2000 5.4 Expedition, 1 - '90 I6, 1 - '92 I6, 1 - '92 302, 1 - '95 302, and 1 - '95 351. I've built engines and done a lot of my own work. Learning the hard way and the easy way.
If anybody has any ideas, I'd appreciate any thoughts, ideas, and feedback.
