Compressor came in yesterday morning. Got it installed and all appears to be good now. Took forever to re-inflate actually put a tape measure on the wheel well to verify it was moving
Install wasn't too bad. Took out the right headlight and the bottom 3 screws on the wheel well. This gave access to the 3 big bolts holding the compressor mounting bracket. Took them out and pulled the compressor and bracket together. Installed new pump in the garage and put the assembly back in.
A couple comments on
the replacement pump that I bought. The unit did not ship with the yellow air filter so I think the new pump will be susceptible to water/moisture ingress. I filed a 1 star review on amazon.
A couple comments on the symptoms before it failed....
At first I thought, "man the pump is running way more than it used to..." In retrospect, I think that the pump just became much more noisy and noticeable. It is possible that it lost some efficiency and had to run longer than before. I don't think the system was losing air since the rear end never appeared to sink over night. When the pump died the controller vented the system and lowered the rear end though.
Thanks for the help on this forum. If I have any continued problems, I'll post back.
