The truck has 200,000 miles. I thought it was the struts. But I replaced all four of those. Also did the tie rod ends, the sway bar bushings and end links, and checked the ball joints with a 6' san angelo bar. There is no movement in the lower ball joints or anything that I can see. When you go over bumps down the driveway it's a pretty loud rattle clunky sound. It sounds bad, and it's gotten progressively worse but I can't find it and my local shop seems to be cluleless. It's especially noticeable under my feet and when you go over speed bumps with one tire or the other. If you go over with both, you don't really hear it unless you hit it hard.
I've been wrenching on Fords for 30 years, and this has be completely stumped.
