2013 Turn Signal Flasher
Z
ZMJohnson
Houston
It's possible it was added after the 2013 model year, or it could be tied to another module. I suggest checking to see if any earlier model year F150s had the setting someplace, as many of the configuration settings overlap. If you can't find the setting in Forscan you may need to add a resistor.
Yeah, I may just add resistors. I looked in each and every menu and the only thing I found was one setting for detecting outages. When I changed that, it still hyper flashed. It looks like I am going to be adding resistors. Thanks though.
JasonH
Houston, TX
Disabling the outage setting for the rear lamp should have fixed the hyperflash. Can you post a screen shot of the setting you changed?
hsquared360
