I think you have to press the brake pedal to crank, regardless of park and neutral. Maybe your brake switch is bad? There are two or more brake switches that measure the brake fluid pressure as well as pedal depressed. Are your brake lights working properly? If you spent $1000 at a dealership they owe you a better diagnosis.It wouldn't start again this morning but this afternoon it started right up. I can't figure out what is wrong. Any suggestions?
Do you have more than 1 ignition key on the ring? Sometimes PATS gets fooled if you have multiple keys hear the ignition lock.My problems started a few weeks ago. First the Passive anti theft system said it had been activated. After three visits to one garage and one dealership, they replaced the transponder ad reprogrammed the keys and said thr the problem was fixed. $1,000 spent.
The next week it wouldn't start in park. Had it towed to dealership again. It started for them and the couldn't duplicate the problemm. Two days later, same thing. It wouldn't start in park or neutral. Took it to my garage and asked for them to replace the park neutral safety switch. Their technician couldn't duplicate my problem and said it started 100 times in 4 days. Took it home and now 2 days later same problem.
I don't know what to do. It's totally unreliable. Any suggestions?
