2014 Limited EL transfer case in neutral for flat towing
jhogan04
How to put 2014 Limited EL transfer case in neutral for flat towing - I can't locate advanced system settings on radio display or dash display. Is it possible this model may not have access to this feature?
bloodhound
Merica
From your owner's manual:
Follow these guidelines if you have a need for recreational towing, such
as towing your vehicle behind a motorhome. We designed these
guidelines to prevent damage to your transmission.
Do not tow your vehicle with any wheels on the ground as transmission
or vehicle damage may occur. It is recommended to tow your vehicle
with all four (4) wheels off the ground, such as when using a car-hauling
trailer. Otherwise, you cannot tow your vehicle. See an authorized dealer
if you must flat-tow a vehicle equipped with the Control Trac®
four–wheel drive system.
67fe390
