2014 limited Expy heated seat switch won’t stay lit
Ron1978
Ms
When I push the heated seat button it glows for brief second the cuts off, so does a/c cooled seat switch. What could be going on?
Ron1978
Ron1978
Ms
???? Any idea what it could be
Ron1978
Ron1978
Ms
Has anyone took the passenger seat out to fix the ground wire that’s bad?? I’m getting ready to do the job and any help would be appreciated
Ron1978
Ron1978
Ms
Ok need some advice, the new Ford wire harness I got has a extra wire right next to the burned out plug wire , I see in videos it says to use both wires as a ground instead of 1. The videos I’ve watched on you tube says it’s also a ground next to it to use both wires as 1 so the controller doesn’t get so hot and melt again. Do I do this??
Ron1978
Ron1978
Ms
Well I wired it and put both the grounds together, worked great.
Alex the First
Pennsylvania
I have pretty much the same issue - push the button, the light comes on for a moment, and then shuts off with no heating or cooling. Could you tell me what all you replaced? the wiring harness? the controller? From where did you buy them?
Expensedition
Newport, RI
I have a 2014 Limited, Heated/cooled seats, same problem, light goes out on both. Seems like a resistance/heat issue with a connector/terminal. I am going to dig into it. Thanks for the insight so far.
