Whenever the outside temperature reaches 90+ the fan blows very loudly. It is noticeable when inside the vehicle but outside it almost sounds more like a jet idling then an expedition.
Is this normal or is it a known issue?
Thanks!
I have a 2015 Expediton Limited 4x4, purchased new.
Last year, when the temperature was about 95 degrees with high humidity, the cooling fans began to roar on mine. It did not do it during the summer of 2015. The vehicle is used strictly for passenger use - no towing or hauling heavy cargo.
I was so concerned (I even had people comment about the excessive noise while getting gas with the engine running) that I took it back to the selling dealer service department.
I was told the noise was normal during very high ambient temperatures (no mention in the owner's manual....). The service department did say there was a TSB to update the HVAC system, so that was done.
This year, the vehicle continues to make the loud roaring noise when the ambient temperature exceeds about 90 degree F. I suspect the vehicle's computer is programmed to turn on the fans for an "extra high / fast" setting during certain times. I have never owned a motor vehicle with electric fans that are as loud as my Expediton when the temperature is hot.
