2015, Upgrade to Heavy Duty Towing
JasonH
Houston, TX
My '16 is a 4x4 XLT EL w/o the heavy duty tow, and has 3.73 gears. I'm thinking all 4x4 EL's have 3.73, and I've heard all EL's in general have them too. Not sure about the 2WDs though.
Some of the 2WD ELs with HD Tow are 3.31. The 3.73 was an option with the LSD.
HavasuMike
Lake Havasu City, AZ
Went to order the parts for the upgrade to my 2016. Got the cooler and one of the tubes, but when I went to order BL3Z-7B028, I got 3 different items. -A says lower return pipe, -C says lower return tube, and -B says says automatic transmission oil cooler hose assemble. Anyone know which one to order?
B
Bigfishfin
Wenatchee, WA
Seems the problem is the ending letter in the part number...
Off of my original order:
7L1Z-7A095-B...Trans cooler
FL1Z-7C410-A....Inlet tube
BL3Z-7B028-C...Pressure line
9L8Z-7Z465-A...Pressure line connector (in case of breakage of this nylon part)
N804837-S...Sight shield retainer (You might consider a few of these because of breakage removing the top trim piece)
This is of course for a 2015 Expy!...Hope this ends confusion!...
nater
Colorado
I highly recommend the larger trans cooler, part number
DL3Z-7A095-B
You will need to cut the top hose exactly 2.5" but otherwise it is a perfect fit and has twice the cooling capacity.
Here it is mounted in my Expy:
Scott Lundberg
Benson, az
Hi guys, I know this thread is old but I hope someone has some input! I just got my transmission cooler today, and while looking it over, noticed that there is no inlet or outlet labeling.
Might seem like a dumb question, but does the direction of flow matter? Or either way it is installed will work? Help! Thank you in advance!
Anthony DeVor
Maryland
Howdy!...I wanted an Expy to replace my very old Durango, and did research on late model Expys to see what would fit my needs. A major requirement is that I have a cargo trailer I pull frequently and thus needed a HD tow package. In my investigation, (aided by this forum, thank you all) was information that trailer wiring for a 7 way plug was largely a factory wired item for the standard XLT and the stock hitch receiver was class 4. In addition, I checked high and low and could find NO viable evidence there is in fact a "standard VS HD" radiator option, (checked online and with local dealership parts dept.) To be clear, only one radiator is available, that I could find, and the fin count on my stock unit is 19 per inch, which some postings of Ford pickups, etc., indicate to be HD.
So, the only issues I could find that would prevent me from having the factory equivalent HD tow package on a standard late model XLT was: 3.31 differential gearing, an auxiliary transmission cooler and a trailer brake controller.
Armed with this information, I search for and found a 2015 XLT with low miles. I have now added the 10 gauge battery wire from the plug under the power brake unit to the rear and installed a 7 way plug, added a factory transmission cooler and a trailer brake controller. All this cost about $300.00 and my time of maybe 5 hours (used to twist wrenches). The only difference I see now from this rig having a factory HD tow package (15,200 lb GVW) is the 3.31 gearing as opposed to the 3.73 gearing and I don't consider that an issue because of the minor 0.42 gearing difference as well as the low rpm torque range of the Ecoboost. I also use a weight distributing hitch on my trailer. BTW, tows great!...
Any thoughts? Have photos of transmission cooler install if interested.
Where did you get 15K tow capacity? The expeditions to my knowledge can only tow up to 9,200lbs according to the manual and that is at most. Thanks
LovinPSDs
Houston
That’s gross combined (SUV + Trailer)
just remember there are lots of numbers, all have to be in line to be legit. Gross, payload, rear axle, hitch, etc
Anthony DeVor
Maryland
Ok that makes sense now lol. I was thinking you maybe swapped an expy body onto a working superduty frame and engine etc. lol :)
