2017 cooling fans running continuously
14expy919
Raleigh, NC
I changed the sensor/transducer, the fan no longer comes on high when the vehicle is started, without the A/C, so that's good. However, when the A/C is turned on, the fan comes on high and does not stop even when the A/C is turned off. I guess I'll be doing some more research.
The car has 93,700 miles on it. The coolant level is good and engine temp is normal, +/- 196°F operating temp.
I'm having same issue, changed high pressure switch without resolution. Do you have any ideas still?? Thanks
randers9
Omaha, NE
Hi. I have the same issue with my 2017 Expedition El xlt. I am leaning towards changing the coolant temp sensor but it looks like a pain to get to. Has anyone on here figured out any definite cause for the fans kicking on high? I mean it is 20 degrees F out and it still kicks on right after starting.
dkincaid32
texas
Not to hijack an old thread but I had the same issue and am here to suggest a possible fix.
In my case, the AC ended up being .5lbs low on refrigerant (system takes 2.5lbs). After refilling, the fans are back to normal and only cycle-on on really hot humid days when extended idling.
