2017 overheating
Ronald 456
Manchester Tn.
My 2017 overheating pulling a 4,500 lb. Travel trailer. Never got hot on level ground but once I start up hill it overheats in less then 2 or 3 minutes. Watching Trans. Temp I notice it jumps up to 230 quick, but I never loose any coolest. Had it to the shop twice. It just started this . No dip stick to ck. Transmission oil level.
99WhiteC5Coupe
Do you have the HD cooling package? Were you using the tow / haul mode?
What do you feed is overheating - the transmission or the engine (or both).
Does the DIC show an overheat situation - or do you feel it is overheating due to the transmission temperature displayed when you check it via the DIC?
Boostedbus
Maryland
I’d start with checking the electric fan and fan relays. I know on my 17 the fans increase speeds as needed all the way up to warp speed. It sounds like it would suck you in through the grille like a jet turbine engine.
JasonH
Houston, TX
The dipstick can be accessed from beneath the vehicle. It's under the fluid filler screw. You didn't say what trim you have. Did the vehicle go into limp mode, or are you saying it overheated because of the temps? My camper is 7,000 lbs and I've never had an issue with overheating, even up grades.
R
Ronald 456
Manchester Tn.
It went in limp mode. Dealer can't find any problem. It has never had a problem in the Mt. Before
99WhiteC5Coupe
By going into limp mode, there has to be one or more trouble codes stored.
What did the dealer tell you about any stored codes?
Timo2824
Wichita
How many miles and has the water pump been checked? This gen has a known issue with the pump impeller blades failing above 80,000 miles.
