2018 Navigator can’t disable seatbelt warning
Artie
Georgia
so I change the value to disable the seatbelt warning but it gives me an error ‘Service procedure has been interrupted’. Has ford made some items impossible to change?
Artie
Artie
Georgia
I wonder what I’m trying to change then. The double honk I was able to disable, at least that worked. What happens if I change something I think is one thing and turns out to be completely different?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
The risk of Forscan and why you should save the module before you make changes.
Artie
Artie
Georgia
True, I have all the modules backed up for this reason. I guess I should change anything back that doesn’t give the expected change instead of driving around wondering what I changed. I did just read in the 2018 FORScan thread about not being able to write to the module with the seatbelt yet so that explains that.
