2019ExpeditionMax
Looking for a little help. New to Forscan, and need a little guidance or confirmation I'm on the right path. We bought my wife a new car a few months ago and it came with some aftermarket tires and a small lift (looks awesome, she and kids are happy - I'm happy). That said the speedometer is off and I'd like to change it. I have looked at many of the forums, but the tire codes I found were for F150s or 2017's
Anyways looks like the code should (but I'm not 100%) be: BCM 726-12-01 : xxxx 0000 xxxx
I made this change and actually got the speedometer right but I had a code U0422 (invalid data received from body control module.) from the PCM & TCM. Makes me feel it's the wrong code. I decided to be cautious and switch it back. The code was gone. I know for some they wanted you to do a PCM relearn, but I believe that only applied to P0160 code which I did not have. I'm looking to calibrate the speedometer and have no codes.
Some other data if it's helpful:
The sheets I have reviewed are:
https://docs.google.com/spreadsheets/d/1uDSQ1Z5a2Wt8-kjrSiVSlDFGFHnfeuhb3RTMVz95730/edit#gid=0
https://docs.google.com/spreadsheets/d/10O3UQDPxl5SGFDDr0dleG5BpB1c4L5Ob/edit#gid=1597179673
https://docs.google.com/spreadsheets/d/1mWnuQZlDTUGjKjmJje1QJIR8Z2c7Kf8KBZxKnw_8EqU/edit#gid=0
Final Note:
I also disabled the double honk, and I had no issues.
Thanks in advance, hopefully, I'm just missing something simple. Also, I've seen people mention "drop-down menus" in the modules, but I have never seen that just the lines of code.
Paul from Utah.
- I have a Lifetime Forscan license
- running version 2.3.36 Beta (what I got when I downloaded it from the site)
- Tires: Nitto Grappler 35x12.5xR20
Final Note:
Paul from Utah.
