2020 6 speaker will the B/O sub box fit?
pinfield357
Pittsburgh PA
Does anyone know if I can buy a B/O sub enclosure and install it into my vehicle that does not have a B/O audio system. I know that I'll be running wires, but I'm planning on changing the speaker and adding an amp. So running wires was always on my plans. I just want to know if I can utilize the B/O enclosure.
HILLY
Greenville, SC
I bought an enclosure for a reasonable amount from an auto recycler off ebay. The box looks to be of sufficient volume and quite sturdy. The key is finding a sub to work in the hole & depth dimensions as it a little bit proprietary (at least the cutout) - still a general 10".
Instead of buying a whole new panel to accomodate the enclosure, my plan is to go this route.
Left Coast Geek
Mid Left Coast
according to my 2019 wiring diagram the 12 speaker has a DSP module that drives most of the speakers (the front tweeters and the D pillar rear tweeters come directly off the audio unit, everything else comes off the DSP), but the sub while drawn like a speaker, with dual voice coils and 2 pairs of inputs coming from that DSP, is labeled as 'sub amplifier'. The 6 speaker version doesn't have this DSP module at all. The input to the DSP is a digital pair coming from the Audio Unit (presumably the stereo itself). Hmmm, C466, the connector to this 'subwoofer amplifier' has only 4 pins with the + and - speaker outputs from the DSP.
P
pinfield357
Pittsburgh PA
Im not worried about the wiring, I just want to know if the B/O enclosure will physically fit in a 6 speaker Expedition
