Timothy Trudeau
I have been working on alot of ford water leaks lately just wanted to post this so others can be informed. as some of us know there is a problem with the ac system leaking into the vehicle on 2018-20 Ford f150s and a few other models I just found a new one on a brand new 2020 expedition I assume the leak was the a A/C in the right front but seen the fix in the drain tube was already done I had water tested the truck and found that water was coming in the front piller took the fender liner loose and found that from the factory the body plugs were not installed on the lower piller keep an eye out for this as well when looking for leaking
