2022 Timberline Stock Tire Issues - Recommendation For New Tire Type?
KetMalice
Oklahoma
So I have a 2022 Timberline with 48k miles. It has been 90% highway miles. I have two tires that I have had to put air in every couple of months. Over the weekend the light came on for one of the tires and I inspected the tires pretty thoroughly. It just so happened to have rained hard for 2 days straight, when I was looking for nails etc. I saw that in between the treads the tire is basically rotting and I could see dozens of air bubbles where air is escaping from my tire. It's bad on two of the tires and I noticed it on 1 other tire.
So, with 5k miles I ended up running over something and it ruined the tire, so 1 I had to replace. I wonder if there's some issue with the batch of tires Ford put on at the factory. That seems really dangerous. I attached a photo, it's easier to see on a video I took. But lots of places where bubbles are forming on the cracks.
I think I may want to replace the tires with something else. Has anyone else had good luck with some other tires? I am okay with some aggressive tires.
I've had several sets of BF Goodwrench All Terrain T/A tires on other vehicles before. Thinking about putting them on.
Shakeandbake
Somewhere
I'm getting ready to order the Falken AT4 in stock size, but I'm worried about running into vibrations at higher speeds.
One thing I noticed on the Timberline stock tires, is that the tread pattern looks like nothing else in the A/T category. Its got these jagged vertical veins (vertical like a street tire).
Left Coast Geek
Mid Left Coast
50K miles is pretty good mileage for a OE tire, but tread cracking at about 2 years old sounds sketchy.
BFG All Terrain KO2's are excellent tires, but expensive. they are good on road and off-road, good in dry, wet, and snow, and surprisingly quiet for a serious offroader, and they last a decently long time.
K
KetMalice
Oklahoma
I ended up putting KO3’s on. I went to discount tire and they were able to give me $50 credit for each of my tires under Good Years warranty.
They look good, so far it’s not that bad on sound and handling.
Left Coast Geek
Mid Left Coast
I've used the KO2's for a lotta miles on a Tacoma 4x4, and a F250 4x4, and they lasted a long time and never disappointed. as soon as the crappy OE Goodyear Wranglers on my 18s wear out halfway, I am going to put a full set of Ko2 or KO3 ..
SyndicateZ
Mass
I love my Sailun Terramax HLT tires. Super quiet and no vibratiin at highway speeds as well
cptbligh
GA
I'm thinking about trying the Continental TerrainContact AT tire next time. Tread looks more highway oriented but the sidewall appears decently aggressive looking. I've been really happy with the Toyo AT3 I have on my F150 though, seem better in the rain than the KOs
Going_Going_Gone
Phoenix
Ours is not a Timberline, but we went with Continental Terrain Contact AT on our Expedition. Semi-aggressive tread but no road noise and long tread life warranty. Probably overkill for the desert, but doing some road tripping to CO later this month
CDNRabbit
Ontario Canada
Not Timberline but for highway driving I'm really happy with the Continental Cross Contact I installed last week. Road noise and bump absorption is significantly better than the General Grabbers.
MAC1
Chester County, PA
I have used the Sumitomo Encounter HT almost since new, it is an E rated tire for towing, great tires, long lasting, very durable and stable if towing.
Left Coast Geek
Mid Left Coast
Interesting that you should say that, since the Wrangler SR-A's on my 011 have over 75k on them (mixed use) and still have a good bit of tread left and only 1 developed a vey slow leak, which I corrected with Fix-A-Flat 2 years ago, notttaproblemo since then...
the 18" OE Wranglers I have are from an F150 'appearance package', are the GOODYEAR WRANGLER TERRITORY AT. Classic 'cheap OE sorta-all-terrain' tires. they don't have very good traction, even dry pavement.
Broncoholic
Space Coast, FL
I've had Terrain Contacts since Dec 2021 and I've been very happy with them. I have lift and 315/70R17's, but 98% of my driving is on the road, so I focused my search on a tread that would be good in Florida's rains. These have not disappointed.
edwin2514532
fla
My 2007 expedition el came with scorpion tires. I have replace them once . I have been happy with them and I have 125k miles on the vehicle and luckly never have had a flat tire with those tires.
Flying N
With quite a bit of research these were one of the tires I was seriously considering in the 275/50r22 size, but ended up going with Yokohama A/T G015 in the 285/50 size because of the price I found. (prefer smaller wheels with taller tires, but not in the budget righ now). Similiar to the Cont Tarrain Contact A/T, these are not a real agressive A/T, and with 90%+ driving on roads/hwy I didn't want an agressive A/T tire. Only have a couple of hundred miles on them so far so too early to give much of a review, other than they ride very well, especially for an E rated 3 ply sidewall tire, and are nearly as quiet as the GoodYear Tour tires that were on it.
TimberExpy
Florida
Do you mind sharing photos of how the KO3s look on the truck? Your reply is from July of this year, and I didn't think that the KO3s were even released yet in the OEM size that early (assuming of course that you put the OEM size on). It's my understanding that BFG is releasing this new tire in phases over the course of the year.
EDIT: oops, I now see that another member has posted photos with KO3s, although they are 275/70R18s rather than stock P265/70R18. Feel free to still share photos though.
Thanks!
Mack444
CA
My OE Timberline tires popped on the sidewall when I u-turned on gravel…so replaced with KO3s. Wonder if they had crack and bubble issues like yours.
Mack444
CA
I don’t give much attention to MPG any longer, but it has certainly decreased at least some. I gave up paying attention all the years we had a lifted Excursion. The rotating mass difference alone (40# vs 65#) is significant. I spend most of my around towning in sport mode and freeway jumps in Eco, so quite a dichotomy in my daily. KO3 vs the KO2 on my Excursion, it’s a comparable replacement. Have yet to experience snow or real off-roading.
