I had my 23’ Stealth in for vibration and rubbing/grinding noise at start up. Vibration isn’t bad, I hardly drive it, wife does. I figured with 30k miles I need to rotate and balance, so they did. They also didn’t find any noise at startup. However I’ve since captured an audio file. It’s kinda long but listen to the end where I tap the throttle, it’s the same rattling/rubbing noise. See SSM52610 and 52295. I am curious if you guys experiencing vibration also hear this noise. If the bolts are loose to the flex plate, or under torqued, this would definitely cause a vibration. Replace the xx with tt
hxxps://drive.google.com/file/d/1v9FsHVtW1GcKKzVFZyaKsUVzLTfEu92a/view?usp=drivesdk
That noise is the wastegate, scratch that theory.
