Ok, I have Forscan on my laptop now. Any suggestions on which connection device I should get? Prices are all over the place from $15 to expensive….and many look exactly alike except for the price!
I second
@bb37. I have been using FORScan for years, both personally and commercially.
The only 2 adapters that work 100% are. I have both. And the switchless feature, on both, is worth 2 times more:
OBDLink EX - More expensive
Works perfectly
Made for FORScan and recommended by the FORScan team
100% coverage of Ford modules and all features offered by FORScan
Electronic MS-CAN/HS-CAN switch allows FORScan to access all CAN buses simultaneously and enables advanced functions not possible with “toggle switch” adapters
Maximum throughput: up to 20 times faster than “toggle switch” adapters
Dealership-level diagnostics — OBDLink EX supports all Ford protocols, modules, and advanced features of FORScan
Rock-solid connection avoids data corruption and dropped packets
BatterySaver™ Technology low power mode
and
Vgate vLinker FS OBD2 USB Adapter for FORScan HS/MS-CAN Auto Switch - cheaper
Also works perfectly and as good as the OBDLink EX
