Updates:
I tried the manual release and checking the latches, everything was fine. I even pushed on the seats prior to and they would not budge, so they seem to be in a fail-secure mode if anything. Went to check the fuses and disconnected the battery, after that everything started working like normal, no faults on the dash and the easy entry/exit button the shoulder of the seats worked, as well as the buttons in the cargo area. It was both seats in the second row that had the fault, and both cleared immediately after a "soft reset/power cycle." I noticed that the truck also recently had an update on the DDM which was for door releases not functioning in certain events, but for some reason I'm not seeing it in my phone's app for recent updates. I'm going to assume that something glitched in the update, and just like the old joke comparing Windows to Ford, it just needed a restart. If it pops up again then I'll assume it's more than software and get it checked out and take that SSM number to the dealer. But with them being an hour away, I'm not spending half a day to drive down for them to do the same thing. Now if only I could get the open on approach split gate to work I'd be happy
