If you have a 4x4, the front transfer case gets in the way of the Godzilla oil pan, best option to work around it is looking like a solid axle swap and ditching the independent suspension that way we can get the clearance needed for the oil pan. Plus side to this is I’ll be able to do a real suspension lift and not just the standard ready lift spacers. The OBR harness and ECU with the USSHIFT trans controller is the option we went with and we will be removing that transfer case to fit and hopefully install the engine this week to run it in 2wd to test it, then it’s back to the shop for the axles that way I can have 4x4 again. I’m sourcing axles from a 93 f350. Dana 60 front and a sterling rear in 10:25. Hopefully will be a smoother job. Plus I’ll be able to get some 37’s on my car now no issue.
Costs are adding up quickly, this is not for the easily scared client to try. I’ll be $20k+ into just parts soon and that could go up even more if there are more issues we don’t know about yet. Plus you’ll need to source a relatively clean f350 for its axles which has been not so easy.
The 6R80 trans will work just fine, unless your thinking of doing a pro charger, turbos, or whipple. Then you’ll need to upgrade with a stage 3 kit like I’m planning to do once the whipple is available.
If you have a 2wd, Godzilla should be a pretty straight up job with the new harness and ecu.
