3rd Gen HVAC Control Unit compatibility
5pencer
Nevada
My 3rd Gen 2011 Expy has had an issue with the resistors needing to be replaced more regularly than possibly normal. I replaced the resistor and its harness per known issues.
I went deeper and found the connector to blower speed switch was partially melted, so I’m now opting to replace the HVAC Control Unit as a possible culprit.
I found h no it from a 2009 Expy and upon install I found that two of the connectors don’t quite match. It both big multi-pin connectors, not the melted harness connector.
My 2011 unit is the FoMoCo-19980-ENMHA model.
The 2009 unit is the FoMoCo-19980-DZU7A model.
I was able to force the connector in and everything seemed to function properly: Heat, A/C, all the speeds and temps and I think all the vent settings, but I didn’t try defrost.
I know there are a couple electronic boards inside the HVAC Control Unit, and ai imagine they maybe sensitive and have different operational specifications.
My question is could there be some electronic programming that is different between those units that may make my swap fail?IMG_4337.jpeg
Gary Waugh
Princeton, TX
The connectors look the same to me on both units, have you checked that there wasn’t a bent pin inside the connector that was making it difficult to fit the plug? I would consider unplugging the connector that you had to force and just make sure no pins are bent. If all looks good then try plugging them back together, but if a pin is bent, try to straighten it with some long nose pliers and then reconnect the plug.
5pencer
Nevada
No bent pins. The original connector on my had a snap release and I had to cut one into the new unit. But I think the issue is the guides. If you look close on the blue connector, there is a shelf on one down inside the connector that isn’t on the other one. I’ve connected them several time and the fitting just bulges out, but all the pins connect.
Staff online
Al_Harley
