4th Gen Expy FORScan Modifications
Discussion in 'FORScan' started by rcompart, Dec 30, 2017.
  1. TheDoug
    TheDoug Active Member
    40
    41
    20
    Apr 20, 2019
    Arlington, TX
    Just got around to messing with the software and I got most things to work however...
    The data entry while in motion tells me I need to check for a typo. (I used the numbers at the beginning of this thread)
    Also auto start stop disable says IPC needs to be modified as well butmi did not see that in FORscan
    Anyone have these issues? I am using the latest beta ending in .24
  2. BoinLV
    BoinLV New Member
    Nov 28, 2018
    Las Vegas, NV
    ROOKIE QUESTION:
    I am assuming "BCM" is a different module than "BdyCM as built" Correct? Seems like any module I access that doesn't state "as built" gives language yes/no options, rather than addresses and values. So, if a mod indicates BCM module, with values and addresses, should I use BdyCM as built? Sorry if this is lame...
    Bo
  3. TheDoug
    40
    41
    20
    Apr 20, 2019
    Arlington, TX
    I am new at this too... but the ones that have yes/no are ones FORscan has made easier for you instead of changing the hex values manually.
    In my post just before yours, all mine were done with the yes/no toggle.
  4. jgudnason
    jgudnason Full Access Members
    40
    100
    32
    Jan 16, 2018
    Calgary, Ab, Canada
    I just checked forscan and looks like there was an update last week and maybe we finally have ability to write to the IPC.
    haven't downloaded and tried yet, anyone else?
    2.3.24 beta, 2019-08-05 (download)
    + Vehicle database update
    + Some BdyCM module configuration parameters for:
    • Edge 2015-2019 model years
    • Expedition 2018-2019 model years
    • Lincoln Navigator 2018-2019 model years
    • Ka/Figo 2018 model year
    • + Some IPC module configuration parameters for:
    • Explorer 2020 model year
    • Kuga/Escape 2017+ model years
  5. Page W Sutton
    Page W Sutton Member
    60
    22
    Jan 27, 2019
    Memphis, Tn
    None of the IPC writes I did were successful.
  6. Page W Sutton
    60
    22
    Jan 27, 2019
    Memphis, Tn
    I also got the typo error when trying to program the data entry whilst moving option. There is a audio/audio video option for data entry in that module that can be accessed via the menu vs hex code perhaps that is it
  7. Breaker
    Breaker Full Access Members
    37
    51
    Aug 1, 2019
    Katy, Texas
    So no codes as of yet for the 2019 Expys, correct? I really want to change out my front turn signals to LED switchbacks, but don't want to wire in the resistors.
  8. tmorris
    tmorris New Member
    Jul 24, 2019
    US
    I understand Ver. 2.3.25 Beta is being tested and is finally allowing writes to IPC on the 2019's. Good news if true. Hopefully will be available soon!
  9. Breaker
    37
    51
    Aug 1, 2019
    Katy, Texas
    That would be awesome! There are a few things I want to turn off. I also have another obstacle, it's my wife's Expy that I'm doing stuff to. LOL She wants me to leave it alone, but I'm like no, we can make it so much better!
Share This Page
