bushpilot
I have spent an hour today trying to test settings. The BCM in the 2020 addressing is NOT the same. Nothing works. I stumbled across one thing that did, but it was a previous change I was trying. I think I can map it out, but I need to compare the 2019 file that Wakeboarder sent me line for line...and see if I can find the patterns & similarities. Have a message in to my friend on the FORSCAN dev team to see if he can find the pattern.
All but the Forward Distance Alert worked in the IPC that I tried.
In addition the 2020's only have 1 color LED's installed. I forced the change in the DDM, and they did not change color.
THANKS!
I was able to get the a few items to work:
- numbers over the gauges
- Seat Heat/Cool icons on center display
- Remove/Skip sirus/xm in audio choices.
I've been unable to get these items working:
- BAMBI
- Disable that dbl horn honk (no key present on exit)
I kinda miss the ambient lighting (that I had on the '17 Super Duty)...only because I prefer red interior lighting at night.
When I enabled the Lincoln display - I got all kinds of new "Lincoln" icons on settings....one of which included AMBIENT Lighting/brightness.
I'd much rather prefer "quick boot" screen and an (all) Black background over the gradient color stuff.
the Lincoln (black screen and quick boot) didn't stick for some reason - it had been working all day, took the Expy out to test the homelink on a gate and I noticed ALL the Lincoln stuff was gone....I've got ambient light (full bright, in blue, no colors options)...but the adjustment is gone from the menu too.
Im wondering if an update got slammed on me (ive turned auto updates OFF <again>)
