Nope. Again. BCM codes for the 18-19’s DO NOT work on the 2020’s. You don’t need the actual codes, if you are running the newest FORSCAN software, it is in the easy selectable options. No need for the code!
Sent from my iPad using Tapatalk Pro
Not sure that is the correct version. As long as it is equal to or later than the version posted in the 2020 thread you should be good.Sorry...just started playing with this last nite. I have 2.3.34beta. Where are the easy options located?
There is BCM as Built, and the other BCM option. One is actual code, and one gives you drop down options. They won't all work for your vehicle, and if they don't it will tell you it can't make the change, or you can just switch it back and apply the previous setting.
It is the far safer way to do FORSCAN. Also, make sure you save a copy of your module before you start making changes, just in case.
The double honk does definitely work.
Yeah, I am VERY comfortable with FORSCAN, and messing with our 2020 got hairy at the beginning, hence the 2020 thread.
I worked with a FORSCAN engineer to determine differences, and gave him copies of my modules in comparison to another member on here's 19, and they very quickly figured out what was going on. Bam, we had a version of FORSCAN that worked with the 2020 Expeditions.
FORD combined modules into the BCM that were previously separate. It is the same on my 2020 Explorer.
Good info @LokiWolf, thank you again!
I was able to get the door chime disable now too - using the IPC Easy config by changing
Chimes Vehicle running with door open - from manual trans to disable.
Upon doing this......does the dash still say door adjar or open or whatever? Just no chime?
