4th Gen rear diff had to be replaced!?!?
bobward757
2024 Expy. Rear differential got chatty and minor shutter accelerating from stop and lower gears. This happened about 5000 miles after having the rear differential fluid changed by the dealership at 50,000 miles.
The first thing they did was put a can of Ford rear differential lubricant in. This was the first step. It did nothing.
Took it back and after a four day diagnosis, I am getting an entire new rear differential. My friendly service advisor is being very tight Lyft and will tell me exactly what the problem is so I used AI and looked it up.
Apparently, according to AI, this might be a bigger problem than I realized. And no one knows whether this replacement differential has any newer electronic slip parts are not.
Does anyone else have any fourth generation experience with this? Is this a growing problem with the fourth gen (like the AI would lead us to believe )or did I just get a lemon?
TIA,
Bob
Yes, rear differential issues are a known and relatively common failure point on recent Ford Expeditionmodels, including the 2024 Ford Expedition. [1, 2]
The primary reasons why this is happening to newer Expeditions include:
1. The Low-Lubricant Factory Recall (Recall 24S05)
Ford issued a specific safety recall (Campaign #24S05 / NHTSA #24V102) affecting certain 2024 models. [1]
    • The Issue: Vehicles were sent from the factory with an inadequate amount of lubricant in the rear axle.
    • The Consequence: Without enough fluid to coat the internal bearings, components quickly overheat, whine, grind, and can suffer catastrophic mechanical failure, requiring a complete replacement of the assembly. [1, 2]
2. Electronic Limited-Slip Differential (eLSD) Component Failures
If your Expedition is equipped with the Heavy-Duty Trailer Tow Package, it features an electronic limited-slip differential (eLSD). The eLSD system has two frequent failure points that often lead mechanics to recommend a total replacement: [1]
    • The eLSD Internal Clutches & Pumps: The internal hydraulic pumps and clutch packs are known to fail, resulting in severe shuddering, binding, or grinding while making slow, tight turns. [1, 2, 3]
    • Actuator Motor Failures: The external Differential Lock Motor / Actuator controls the clutch packs. When it fails, some dealerships or repair centers prefer to swap out the entire rear differential assembly with a used or new unit rather than rebuilding the internal components piece-by-piece. [1]
apex96
PA
Ford safety recall, Campaign #24S05 / NHTSA #24V102, is for the Transit vans and not the expeditions... Affected Vehicles: 2023 and 2024 model year Ford Transit light vehicles manufactured between May 5, 2023, and February 10, 2024
This issue your experiencing is not a wide spread issue. Failures happen unfortunately.
I have an open dif 8.8 rear end that had to be rebuilt at just over 100k and I've serviced it every 50k...
Have it rebuilt and just drive it and try and enjoy it.
gunner1416
