4wd Control Module Location
Sccritterkiller
SC
Anybody now where it is?...I have no 4wd, replaced the motor no dice. It's not getting power, lights on the dash work when I shift...but motor is not moving. I can take the motor off turn the shaft into 4wd and it works fine. It's not the T Case...over 10lbs of vaccum at the IWE in 2wd and it's the vacuum drops down when you shift to 4wd. It's not in the vacuum system, solenoid or IWEs.
2010 Limited EL
Any suggestions?
Sccritterkiller
Sccritterkiller
SC
Maybe it's a relay not a module??? What provides power to the shift motor?
Hamfisted
Ft Lauderdale
You looked in your owners manual right ? There's several fuses and a relay shown there. Somewhere around page 328 and on ....
